[GRASS-dev] grass70 build error on Ubuntu raring
Rashad M mohammedrashadkm at gmail.com
Mon Jun 24 09:55:11 PDT 2013
I am getting compile error on Ubuntu raring for grass70.
>From the short error log (see below) I think its python xml parse error.
probably the new toolbox addition.
Full error log here [1]
7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/gui/wxpython/xml/module_items.xml
  File "tools/build_modules_xml.py", line 85, in <module>
    sys.exit(main())
  File "tools/build_modules_xml.py", line 77, in main
    header(fh)
  File "tools/build_modules_xml.py", line 64, in header
    (vInfo['version'].split('.')[0],
KeyError: 'version'
make[5]: *** [/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/gui/wxpython/xml/module_items.xml]
Error 1
make[5]: Leaving directory
`/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/gui/wxpython'
make[4]: [default] Error 2 (ignored)
/usr/bin/make xml/menudata.xml
make[5]: Entering directory
GISRC=/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/demolocation/.grassrc70
GISBASE=/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu
PATH="/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/bin:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/bin:$PATH"
PYTHONPATH="/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/python:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/python:$PYTHONPATH"
LD_LIBRARY_PATH="/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/bin:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/lib:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/lib:"
LC_ALL=C python core/toolboxes.py > xml/menudata.xml
  File "core/toolboxes.py", line 552, in <module>
    sys.exit(main())
  File "core/toolboxes.py", line 541, in main
    tree = toolboxes2menudata(userDefined=False)
  File "core/toolboxes.py", line 162, in toolboxes2menudata
    moduleItems = etree.parse(moduleItemsFile)
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1182, in parse
    tree.parse(source, parser)
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 657, in parse
    self._root = parser.close()
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1654, in close
    self._raiseerror(v)
  File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1506, in _raiseerror
    raise err
xml.etree.ElementTree.ParseError: no element found: line 4, column 0
make[5]: *** [xml/menudata.xml] Error 1
/usr/bin/make menustrings.py
/usr/bin/install -c  -m 644 xml/menudata.xml
/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/gui/wxpython/xml/menudata.xml
LC_ALL=C python core/menutree.py >> menustrings.py
  File "core/menutree.py", line 227, in <module>
    menudata = LayerManagerMenuData(filename)
  File "/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/gui/wxpython/lmgr/menudata.py",
line 31, in __init__
    MenuTreeModelBuilder.__init__(self, filename)
  File "/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/gui/wxpython/core/menutree.py",
line 61, in __init__
    xmlTree = etree.parse(filename)
    self._raiseerror(v)
    raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
make[5]: *** [menustrings.py] Error 1
[1]
https://launchpadlibrarian.net/143289203/buildlog_ubuntu-raring-amd64.grass70_7.0.0%2B0ubuntu2%2B28653~raring1_FAILEDTOBUILD.txt.gz
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130624/534a2851/attachment-0001.html>
