[GRASS-dev] grass70 build error on Ubuntu raring
    Anna Petrášová
    kratochanna at gmail.com
    Mon Jun 24 10:38:06 PDT 2013
On Mon, Jun 24, 2013 at 6:55 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> Hi,
> I am getting compile error on Ubuntu raring for grass70.
> From the short error log (see below) I think its python xml parse error.
> probably the new toolbox addition.
> Full error log here [1]
what does g.version -rge  and python library function grass.version()
return? Because it seems that in the first part  of the log grass.version()
fails.
Anna
> 7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/gui/wxpython/xml/module_items.xml
> Traceback (most recent call last):
>   File "tools/build_modules_xml.py", line 85, in <module>
>     sys.exit(main())
>   File "tools/build_modules_xml.py", line 77, in main
>     header(fh)
>   File "tools/build_modules_xml.py", line 64, in header
>     (vInfo['version'].split('.')[0],
> KeyError: 'version'
> make[5]: *** [/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/gui/wxpython/xml/module_items.xml] Error 1
> make[5]: Leaving directory `/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/gui/wxpython'
> make[4]: [default] Error 2 (ignored)
> /usr/bin/make xml/menudata.xml
> make[5]: Entering directory `/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/gui/wxpython'
> GISRC=/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/demolocation/.grassrc70 GISBASE=/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu PATH="/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/bin:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/bin:$PATH" PYTHONPATH="/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/python:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/python:$PYTHONPATH" LD_LIBRARY_PATH="/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/bin:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/lib:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/lib:" LC_ALL=C python core/toolboxes.py > xml/menudata.xml
>   File "core/toolboxes.py", line 552, in <module>
>     sys.exit(main())
>   File "core/toolboxes.py", line 541, in main
>     tree = toolboxes2menudata(userDefined=False)
>   File "core/toolboxes.py", line 162, in toolboxes2menudata
>     moduleItems = etree.parse(moduleItemsFile)
>   File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1182, in parse
>     tree.parse(source, parser)
>   File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 657, in parse
>     self._root = parser.close()
>   File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1654, in close
>     self._raiseerror(v)
>   File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1506, in _raiseerror
>     raise err
> xml.etree.ElementTree.ParseError: no element found: line 4, column 0
> make[5]: *** [xml/menudata.xml] Error 1
> /usr/bin/make menustrings.py
> /usr/bin/install -c  -m 644 xml/menudata.xml /build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/gui/wxpython/xml/menudata.xml
> GISRC=/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/demolocation/.grassrc70 GISBASE=/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu PATH="/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/bin:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/bin:$PATH" PYTHONPATH="/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/python:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/etc/python:$PYTHONPATH" LD_LIBRARY_PATH="/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/bin:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/lib:/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/dist.x86_64-pc-linux-gnu/lib:" LC_ALL=C python core/menutree.py >> menustrings.py
>   File "core/menutree.py", line 227, in <module>
>     menudata = LayerManagerMenuData(filename)
>   File "/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/gui/wxpython/lmgr/menudata.py", line 31, in __init__
>     MenuTreeModelBuilder.__init__(self, filename)
>   File "/build/buildd/grass70-7.0.0+0ubuntu2+28653~raring1/gui/wxpython/core/menutree.py", line 61, in __init__
>     xmlTree = etree.parse(filename)
>     self._raiseerror(v)
>     raise err
> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
> make[5]: *** [menustrings.py] Error 1
> [1]
> https://launchpadlibrarian.net/143289203/buildlog_ubuntu-raring-amd64.grass70_7.0.0%2B0ubuntu2%2B28653~raring1_FAILEDTOBUILD.txt.gz
> Regards,
>    Rashad
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130624/5675bbbe/attachment.html>
