[GRASS-dev] [GRASS GIS] #1270: wingrass: Error in Attribute Table Manager
trac at osgeo.org
Mon Mar 11 04:32:47 PDT 2013
Reporter: antonioall | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: wingrass, attribute table manager | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:29 annakrat]:
> There are some other places in digitizer (in vdigit/mapwindow.py) where
the same problem should occur. For example adding new feature to a vector
map (with attributes) should fail because of the same reason but it seems
to work on Windows (please test this case too to be sure).
digitizing tested with
System Info
GRASS version: 6.4.3svn
GRASS SVN Revision: 55310
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.9.2
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
starting to digitize a new vector, defining new columns (integer, double,
varchar, datum) works.
digitizing a new point, line or area, the window to enter attributes pops
up, but '''no''' fields to enter attributes are displayed, on the top of
the popup window there is the message "no attributes found".
furthermore, after finishing digitizing point, line and area, only the
boundary of the area is displayed ( an extra build topology doesn't help),
although there seems point, line and area inside the new vector.
v.info map=testv at user1
| Layer: testv at user1
| Mapset: user1
| Database: C:\grassdata
| Title:
| Map scale: 1:1
| Map format: native
| Name of creator: myricaria
| Organization:
| Source date: Mon Mar 11 12:16:59 2013
| Type of Map: vector (level: 2)
| Number of points: 2 Number of areas: 1
| Number of lines: 2 Number of islands: 1
| Number of boundaries: 1 Number of faces: 0
| Number of centroids: 1 Number of kernels: 0
| Map is 3D: No
| Number of dblinks: 1
| Projection: Lambert Conformal Conic
| N: 227647.21627409 S: 215332.44111349
| E: 644033.19057816 W: 631689.50749465
| Digitization threshold: 0
| Comments:
maybe that's worth for another ticket?
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:30>
