[GRASS-dev] [GRASS GIS] #1270: wingrass: Error in Attribute	Table Manager
    trac at osgeo.org
    Mon Mar 11 04:47:01 PDT 2013
 Reporter:  antonioall                         |       Owner:  grass-dev@…
     Type:  defect                             |      Status:  new
 Priority:  blocker                            |   Milestone:  6.4.3
Component:  wxGUI                              |     Version:  svn-develbranch6
 Keywords:  wingrass, attribute table manager  |    Platform:  MSWindows Vista
      Cpu:  x86-32                             |
Comment(by hellik):
 Replying to [comment:30 hellik]:
 > digitizing tested with
 > System Info
 > GRASS version: 6.4.3svn
 also the same in osgeo4w-wingrass6dev
 > starting to digitize a new vector, defining new columns (integer,
 double, varchar, datum) works.
 > digitizing a new point, line or area, the window to enter attributes
 pops up, but '''no''' fields to enter attributes are displayed, on the top
 of the popup window there is the message "no attributes found".
 > furthermore, after finishing digitizing point, line and area, only the
 boundary of the area is displayed ( an extra build topology doesn't help),
 although there seems point, line and area inside the new vector.
 after a manually ''v.category input=testv at user1 option=add'' to the new
 digitized vector, point, line and area are displaye correctly.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1270#comment:31>
