[GRASS-dev] GRASS 7 wish: Keyword index
Anna Kratochvílová
kratochanna at gmail.com
Tue Mar 12 14:52:16 PDT 2013
On Tue, Mar 12, 2013 at 8:49 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Mar 12, 2013 at 8:34 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On 12 March 2013 19:45, Markus Neteler <neteler at osgeo.org> wrote:
>>> On Tue, Mar 12, 2013 at 6:58 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>>>> Thinking about the style of keywords.html page, I discovered that the
>>>> h2 and h3 have the same font-size in CSS [1]. Is it an intention?
>>> I darkly remember that a font smaller than "medium" (used for h4) seems
>>> to be too small, so h3 and h4 were made the same.
>>> Suggestions are welcome.
>> Hm, for me after deleting font-size setting the page looks good. h2 is
>> bigger than now, h3 is the same as h2 and h3 now. h2 on module page
>> are uppercased, so they may look bit more important by itself. This
>> was maybe the reason for setting the same sizes. I tried to set sizes
>> and get the same result (same sizes). I'm not satisfied but I don't
>> know what to do.
> @all:
> For fun I have deleted the size definitions on the server. You can
> reload the manual to see the effect as suggested by Vaclav.
> Next Saturday it will be overwritten unless changes are committed
> to SVN.
>>>> And about the style itself. I would suggest to use description (dl)
>>>> instead of bullet list. The change in code is small but I don't want
>>>> to do it without asking others.
>>> Can you give an example of improvement?
>> It would be the same as the Flags section at module page (the flag
>> description is <dl>). It would be cleaner than the current state -- no
>> bullets, no double colons. The keyword would be bold (<b>) on separate
>> line and the list of modules would be on the other line.
> Sounds good to me.
Done in r55341. Feel free to revert or change.
> Perhaps, to not mess up the other pages, have some special
> keywords style? Could also go into the page header itself.
Probably no special style is needed.
Anna
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
