[GRASS-dev] compilation of grass on AIX 7.1
Markus Neteler
neteler at osgeo.org
Sun Mar 17 10:22:48 PDT 2013
Ivan,
it might help to get GNU make:
https://svn.osgeo.org/grass/grass/trunk/REQUIREMENTS.html
-> GNU make is recommended (at least version 3.81)
http://www.gnu.org/software/make/make.html
That will likely behave better.
Furthermore:
On Fri, Mar 15, 2013 at 6:02 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> r39731 re-wrote it to use $host. Rather than trying to figure out the
> correct $host value for each possible system (few of which were
> available for testing), the sections for "unused" systems were
> removed, with the intent that they would be added if and when someone
> with access to such a system was able to report the correct $host
> value and which compiler/linker switches actually worked on that
> system.
... your help would be needed to re-enable AIX support.
Markus
