[GRASS-dev] formatting expressions for r.mapcalc in GRASS6.4.3
Markus Neteler
neteler at osgeo.org
Sun Mar 17 15:48:03 PDT 2013
On Sun, Mar 17, 2013 at 12:23 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Replace the split() function in core/utils.py with:
> def split(s):
> """!Platform spefic shlex.split"""
> if sys.platform == "win32":
> return shlex.split(s.replace('\\', r'\\'))
> else:
> return shlex.split(s)
I have tested attached patch (which I hope is the same as the suggested change),
it lead to a complete GUI error. I tried to catch it with a screenshot
but was to
slow. I can try harder if needed.
Markus
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130317/b733cdce/attachment.obj>
