[GRASS-dev] [GRASS GIS] #1903: r.watershed fails with "Subprocess failed with exit code 6"
trac at osgeo.org
Wed Mar 20 07:44:11 PDT 2013
Reporter: marcosc | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Raster | Version: svn-releasebranch64
Keywords: r.watershed | Platform: Linux
Cpu: Unspecified |
Comment(by marcosc):
LFS is enabled, but we are working on a 64-bit platform anyway.
The command:
r.watershed -fm elevation=... accumulation=... drainage=... basin=basins
stream=... threshold=10000 memory=25000 --overwrite --verbose
... with:
g.region -p
rows: 38728
cols: 55611
cells: 2153702808
...results in:
ERROR: G_malloc: unable to allocate 596992000 bytes at setup.c:64
WARNING: Subprocess failed with exit code 256
WARNING: category information for [flow_accumulation] in [r.watershed]
missing or invalid
WARNING: category information for [drainage_direction] in [r.watershed]
missing or invalid
WARNING: category information for [basins] in [r.watershed] missing or
invalid
WARNING: category information for [streams] in [r.watershed] missing or
invalid
Removing raster <MASK>
[H[2JClosing monitors ...
Cleaning up temporary files ...
Done.
The system runs with 32 gb of RAM, so ~600 MB shouldn't be a problem.
We checked the setup.c in /lib/segment/setup.c but could not locate the
problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1903#comment:2>
