[GRASS-dev] [GRASS GIS] #1903: r.watershed fails with "Subprocess failed with exit code 6"
GRASS GIS trac at osgeo.org
Wed Mar 20 08:22:07 PDT 2013
 Reporter:  marcosc      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Raster       |     Version:  svn-releasebranch64
 Keywords:  r.watershed  |    Platform:  Linux
      Cpu:  Unspecified  |
Comment(by mmetz):
 Replying to [comment:2 marcosc]:
 > LFS is enabled, but we are working on a 64-bit platform anyway.
 > The command:
  r.watershed -fm elevation=... accumulation=... drainage=... basin=basins
 stream=... threshold=10000 memory=25000 --overwrite --verbose
 > ... with:
  g.region -p
  rows:       38728
  cols:       55611
  cells:      2153702808
 The number of cells can cause integer overflow because the largest 32bit
 integer is 2147483647 < 2153702808. This limit has been removed in GRASS
 7.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1903#comment:3>
