[GRASS-dev] [GRASS-SVN] r55510 - grass/trunk/temporal/t.vect.univar
Markus Neteler neteler at osgeo.org
Sun Mar 24 06:24:31 PDT 2013
Hi Soeren,
... ein paar weitere gaebe es noch, aber ich moechte nicht in Deinem code
rumpfuschen:
grep fs */*.py | grep -v offset
t.rast3d.univar/t.rast3d.univar.py:#% key: fs
t.rast3d.univar/t.rast3d.univar.py:    fs = options["fs"]
t.rast3d.univar/t.rast3d.univar.py:        "str3ds", input, where,
extended, header, fs)
t.rast.univar/t.rast.univar.py:#% key: fs
t.rast.univar/t.rast.univar.py:    fs = options["fs"]
t.rast.univar/t.rast.univar.py:        "strds", input, where,
t.register/t.register.py:#% key: fs
t.register/t.register.py:    fs = options["fs"]
t.register/t.register.py:        unit=unit, increment=increment,
dbif=None, interval=interval, fs=fs)
t.vect.db.select/t.vect.db.select.py:    fs = options["separator"]
      separator="%s" % (fs), where=where)
t.vect.db.select/t.vect.db.select.py:                            fs, fs, entry)
t.vect.db.select/t.vect.db.select.py:                            print
"%s%s%s%s%s" % (row["start_time"], fs,
                row["end_time"], fs, entry)
              fs, fs, entry)
Schoene Gruesse
Markus
