[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
GRASS GIS trac at osgeo.org
Wed May 1 22:21:04 PDT 2013
  Reporter:  antonioall   |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  critical     |   Milestone:  6.4.3
 Component:  Vector       |     Version:  svn-trunk
Resolution:               |    Keywords:  v.in.lines, g.tempfile
  Platform:  MSWindows 7  |         Cpu:  x86-64
Comment(by hamish):
 Replying to [comment:17 hamish]:
 > it's the `GRASS GIS 6.x Old TclTk GUI` startup menu item which is eating
 the C: part of GISDBASE.
 > specifically this line in lib/init/gis_set.tcl:
  if { [regexp -- {^GISDBASE.*:(.*)$} $thisline dummy env_database] } {
      set database [string trim $env_database]
 > looking into why it isn't like `{|^GISDBASE: \(.*\)$}` already with
 > 'svn blame', looks like r45817 introduced it. Maris, do you remember
 > what the problem is that was fixing, so we can avoid reintroducing it?
 it was a work-around for #1340, which was fixed a long time ago.
 partial revert of r45817 done in devbr6 with r56071.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:21>
