[GRASS-dev] [GRASS GIS] #855: d.text: rotate needs to rotate the background box too
GRASS GIS trac at osgeo.org
Wed May 1 22:44:03 PDT 2013
 Reporter:  hamish   |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.4.4
Component:  Display  |     Version:  svn-develbranch6
 Keywords:  d.text   |    Platform:  All
      Cpu:  All      |
Changes (by hamish):
  * milestone:  6.5.0 => 6.4.4
Old description:
> Hi,
> as pointed out by Rich Shepard on the users mailing list, d.vect fails to
> also rotate the background color-box along with the text.
> there is already rendering code in d.labels to do this, it just needs to
> be incorporated into the d.text code.
> Also, if you had set the background color to "none" it was still getting
> drawn but using the same color as the text. I've just fixed that in
> 6.5svn (r40214). Previously the test for drawing background was just if
> the bgcolor= option was used at all.
> Hamish
New description:
 as pointed out by Rich Shepard on the users mailing list, d.text fails to
 drawn but using the same color as the text. I've just fixed that in 6.5svn
 (r40214). Previously the test for drawing background was just if the
 Hamish
Comment:
 background box of d.text still not rotating..
Ticket URL: <https://trac.osgeo.org/grass/ticket/855#comment:4>
