[GRASS-dev] [GRASS GIS] #943: wxpython gui hangs after switching to cairo display driver
trac at osgeo.org
Wed May 1 23:02:04 PDT 2013
Reporter: epatton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: cairo, driver, gui, wxpython | Platform: Linux
Cpu: All |
Changes (by hamish):
* priority: normal => critical
* component: Display => wxGUI
* milestone: 6.5.0 => 6.4.3
Comment:
ok, seems like two bugs,
[debian/squeeze on amd64, testing in both relbr64 and devbr6, cairo 1.10]
with GRASS_PNG_READ as in the example in comment:1, d.mon still crashes
with,
G643svn> export GRASS_PNG_READ=TRUE
G643svn> d.mon -L
*** glibc detected *** status: free(): invalid pointer:
G643svn> echo $?
1
(as above)
If I `touch map.bmp` first then d.mon runs ok.
So it either needs to test if the file exists and exit with an error, or
test if it exists and skip trying to read it, or create it if it's
missing. (maybe d.mon shouldn't be creating it..)
in the wxGUI preferences, after changing the Map Display -> Display driver
to "cairo" I get this error in the command console:
Settings applied to current session but not saved
ERROR: Rendering failed. Details: File </tmp/tmpsF0WNE.ppm>
not found
however, there is an empty file in /tmp/ called `tmpsF0WNE`. (no .ppm)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/943#comment:9>
