[GRASS-dev] GRASS 6.4.3 release planning
Martin Landa landa.martin at gmail.com
Thu May 2 06:25:08 PDT 2013
2013/5/2 Martin Landa <landa.martin at gmail.com>:
> 2013/5/2 Anna Kratochvílová <kratochanna at gmail.com>:
>> Sorry for delaying, there is a pretty high chance to make cartographic
>> composer (PDF export) working [1]. Tomorrow it will be clear.
> winGRASS compilation launched manually. In two hours there should be
> new build including the last fixes.
build 573 is available. Quick test (raster + vector map) with 6.4.3svn:
* raster map is still missing in preview
* generating PS works*
* generating PDF works*
Martin
* message "Generating ..." doesn't disappear when job is done
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
