[GRASS-dev] GRASS 6.4.3 release planning
Hamish
hamish_b at yahoo.com
Thu May 2 05:19:31 PDT 2013
Markus N wrote:
> What's missing,
here's my wish list of things to get done before 6.4.3-final-
all are either almost done, has-a-patch, or should-be-easy:
#1428: still some missing some dlls (were in earlier pkges)
#1727a: (patch in ticket) script-within-script needs scripts/ in %PATH%
#1727b: (now in devbr6 for testing) tcltk stripping C:\ from GISDBASE
#1849: g.proj needs -t flag (as a hack-around) for datum transforms
#1946: (patch in ticket) clean up .svn in demolocation packaging
#1952: package 'more.exe' with msys (pager for g.list)
#1554: either get ps2pdf wrapper working or hardcode the gswin32.exe
command it calls to get PDF output from the carto composer on wingrass
(work in progress)
#1936a: Move "Click here to show search module engine" to "Search module"
tab, freeing up valuable screen real estate for the output text
window. (rfc)
#1936b: Reword "Protocol" button as "Log file" (strings + docs only)
#854: building addons on Mac (assume we can handle post-release in pkg'ing)
I didn't make it past the first two pages of 6.x tickets, but 25 tickets
able to be closed in the past day is pretty good progress. :)
have a look
all grass 6 bugs: https://trac.osgeo.org/grass/report/16
all wingrass bugs: https://trac.osgeo.org/grass/report/14
all wxgui bugs: https://trac.osgeo.org/grass/report/15
thanks,
Hamish
