[GRASS-dev] [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS installer distribution
GRASS GIS trac at osgeo.org
Sat May 11 19:03:59 PDT 2013
 Reporter:  ddalimonte                 |       Owner:  hamish
     Type:  defect                     |      Status:  new
 Priority:  major                      |   Milestone:  6.4.3
Component:  Projections/Datums         |     Version:  svn-releasebranch64
 Keywords:  r.in.wms, wingrass, cs2cs  |    Platform:  MSWindows XP
      Cpu:  All                        |
Comment(by hamish):
 latest 6.5 nightly wingrass build:
  * GDAL_DATA now set in $GISBASE/etc/env.bat, points to
 $GISBASE/share/gdal/
  * xml2.exe and wget.exe are still not installed with wingrass, but
 curl.exe is there so minimum requirements for r.in.wms[.sh] are fulfilled.
  * script-called-from-script path problem fixed in #1727.
  * r.in.wms examples still need a bit more refreshing work. #1495
 from the msys command prompt:
  `r.in.wms -l mapserver="http://mapserver.flightgear.org/ms"`
 seems to work now, but the parsing is a bit messed up (linux too), if
 xml2.exe was installed that would be a lot better.
 .. work in progress ..
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:46>
