[GRASS-dev] [GRASS GIS] #1747: v.rast.stats on dbf shapefile not enough precision even with DOUBLE PRECISION
trac at osgeo.org
Tue May 14 15:12:24 PDT 2013
PRECISION
Reporter: vesnikos | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: v.rast.stats | Platform: Linux
Cpu: x86-32 |
Comment(by ElcoL):
Replying to [comment:12 hamish]:
> can you also provide the r.slope.aspect command? (r.info -h).
> and can you reproduce it with one of the sample datasets? (spearfish or
NC, so I can try to reproduce it here too)
> thanks,
> Hamish
> ps- no need to explicitly state @PERMANENT, it's automatically in the
map search path.
I reproduced the error with the NC dataset:
v.rast.stats vector=soils_wake at PERMANENT raster=slope at PERMANENT
colprefix=slope
the result is an attribute table with a lot of empty rows and the rows
that do show slope stats all have 2 decimals only
Ticket URL: <https://trac.osgeo.org/grass/ticket/1747#comment:13>
