[GRASS-dev] [GRASS GIS] #1747: v.rast.stats on dbf shapefile not enough precision even with DOUBLE PRECISION
trac at osgeo.org
Tue May 14 16:23:59 PDT 2013
PRECISION
Reporter: vesnikos | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: v.rast.stats | Platform: Linux
Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:13 ElcoL]:
> I reproduced the error with the NC dataset:
ok, thanks, I can reproduce it now too.
(best to work in a user mapset, and not modify the maps in PERMANENT, make
a copy and work on the copy)
It happens because the awk command specifically sets the print format to
"%.2f".
https://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/scripts/v.rast.stats/v.rast.stats#L363
so you only get 2 digits after the decimal place.
seems this came in with r48058 as part of a bulk merge with another
(faster) version of the script, so in 6.4.2+ but not the old+slow 6.4.1
version. I don't see a reason to keep it as %.2f instead of
%.{something}g, any hints Otto?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1747#comment:14>
