[GRASS-dev] [GRASS GIS] #1975: v.overlay.and gets "stuck"
trac at osgeo.org
Thu May 16 02:24:32 PDT 2013
Reporter: kiarasky | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: unspecified
Keywords: | Platform: Linux
Cpu: Unspecified |
Hi all! It's Kiara. I am using a script to overlay two shapefiles,
respectively line and polygon type. The overlay operation gets stuck at
approximately 74%, and it happens in the script, by command line and also
by using the grass toolbox in qgis. maybe the problem is the number of
vertices?
More info: (ALL_ROUTES_M1SO6 is the line map, prova_conc_grand_grass is a
test polygon i'm using)
GRASS 6.4.2 (Europe):~/Desktop/short-term/grass_CODE_NewData > v.overlay
ainput=ALL_ROUTES_M1SO6 at PERMANENT atype=line alayer=1
binput=prova_conc_grand_grass at PERMANENT btype=area blayer=1
output=routes_overlapped_test2 operator=and
Copying vector objects from vector map <ALL_ROUTES_M1SO6 at PERMANENT>...
100%
Collecting input attributes...
<prova_conc_grand_grass at PERMANENT>...
100%
Building partial topology...
Building topology for vector map <routes_overlapped_test2>...
Registering primitives...
869 primitives registered
20203 vertices registered
Number of nodes: 138
Number of primitives: 869
Number of points: 0
Number of lines: 868
Number of boundaries: 1
Number of centroids: 0
Number of areas: -
Number of isles: -
Breaking lines...
^C74%
*** here I stopped the procedure, and after that I cannot open the map
that has been created. My maximum wall time has been 20 minutes...is that
normal?
thanks a lot
Kiara
Ticket URL: <http://trac.osgeo.org/grass/ticket/1975>
