[GRASS-dev] wxgui (module dialog) one "Required" struct Option is necessary to create dialog box
Yann Chemin yann.chemin at gmail.com
Fri May 17 05:59:43 PDT 2013
The module had (i have split them in i.wavelet and i.iwavelet) no input
required. When i enabled one input as required (actually a group input)
then it built the dialog box.
I am making a temporal decomposer/recomposer using wavelet
Y
On May 17, 2013 5:47 PM, "Hamish" <hamish_b at yahoo.com> wrote:
> Yann wrote:
> > the auto creation of dialog box for modules has to have at
> > least one input->required = YES; appearing in the "Required"
> > Tab to build on the fly.
> you can force a UI by adding "--ui" as a command line option.
> > Can somebody help me to remove this requirement.
> > I am building a module that does forward and inverse
> > modeling,
> is it that you see "input" is required, or at least one required
> option? the module typically runs with no options? (like d.erase
> in grass6)
> > (maybe that is why i.fft has a i.ifft sister module)
> i.fft transforms from geographic space to frequency space, and
> i.ifft does the inverse, from freq. space to geographic space.
> The two have nothing to do UI issues, the magic is you get to
> work with the freq. space raster with r.mapcalc and all the other
> raster array tools which don't know the map isn't a DEM or
> similar.
> but maybe I don't get what you mean.
> Hamish
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130517/d473b22e/attachment.html>
