[GRASS-dev] In G7, v.category with option=transfer layer=1, 2 doesn't seem to be effective
Nikos Alexandris nik at nikosalexandris.net
Fri May 17 06:33:48 PDT 2013
In G7
# transfer cats to new layers, as the manual describes [1]
v.category polygons option=transfer layer=1,2 out=polygons_tmp
# checking
v.db.select polygons_tmp
cat|id|cat_
1|1|
v.db.select polygons_tmp layer=2
cat
Shouldn't that work out-of-the box?
N
ps- Related: <http://gis.stackexchange.com/questions/17076/how-to-make-the-layer-2-use-the-same-vector-categories-from-layer-1>
[1] <http://grass.fbk.eu/manuals/html70_user/v.category.html>
Copy categories from layer 1 to layer 2,3,4,5,6,7 and 8
Existing layer will be overwritten, non-existing will be created.
v.category input=observer output=observer_new option=transfer
layer=1,2,3,4,5,6,7,8
