[GRASS-dev] [GRASS GIS] #1849: Cannot create a new GRASS Location using a custom proj4 string
trac at osgeo.org
Fri May 17 23:23:18 PDT 2013
Reporter: voncasec | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Projections/Datums | Version: unspecified
Keywords: proj4, location wizard, wxgui | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
'g.proj -t' work-around in the wxGUI location wizard now applied in all
branches, which seems to make things better when used with proj 4.8.0.
please everyone test all ways of creating all types of locations, both
with proj 4.7.0 and 4.8.0. Don't trust the summary screen, you need to
confirm the result was as expected with 'g.proj -p' from within the new
session.
still haven't done anything about datumtrans=0, my feeling is that it
should remove all datum transform terms to match its description "Do not
apply any datum transforms", so leave it undefined even if proj 4.8.0 has
decided to choose some default terms itself (i.e. strip away the trying-
to-be-helpfulness).
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:13>
