[GRASS-dev] [GRASS GIS] #943: wxpython gui hangs after switching to cairo display driver
trac at osgeo.org
Sat May 18 00:49:19 PDT 2013
Reporter: epatton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: cairo, driver, gui, wxpython | Platform: Linux
Cpu: All |
Comment(by hamish):
the following patch against devbr6 changes the error message from "File
<...> not found" to "ERROR: Rendering failed. Details: Error reading PPM
file" (the file exists but is empty).
Index: gui/wxpython/core/render.py
--- gui/wxpython/core/render.py (revision 56191)
+++ gui/wxpython/core/render.py (working copy)
@@ -87,13 +87,14 @@
self.opacity, self.hidden))
# generated file for each layer
- self.gtemp = tempfile.mkstemp()[1]
- self.maskfile = self.gtemp + ".pgm"
if self.type == 'overlay':
- self.mapfile = self.gtemp + ".png"
+ tempfile_sfx =".png"
else:
- self.mapfile = self.gtemp + ".ppm"
+ tempfile_sfx =".ppm"
+ self.mapfile = tempfile.mkstemp(suffix = tempfile_sfx)[1]
+ # do we need to `touch` the maskfile so it exists?
+ self.maskfile = self.mapfile.rsplit(".",1)[0] + ".pgm"
def __del__(self):
Debug.msg (3, "Layer.__del__(): layer=%s, cmd='%s'" %
(self.name, self.GetCmd(string = True)))
shooting in the dark:
I guess the error means that g.pnmcomp is trying to read from the existing
GRASS_CAIROFILE before adding to it as GRASS_CAIRO_READ is set(?), or
maybe the GRASS_RENDER_IMMEDIATE=TRUE is causing the PNG driver to be used
instead?
(I notice GRASS_PNG_READ is referenced in a few places, but
GRASS_CAIRO_READ is not at all)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/943#comment:10>
