[GRASS-dev] [GRASS GIS] #560: WinGRASS not deleting temp ppm files from map display
trac at osgeo.org
Sat May 18 04:42:02 PDT 2013
Reporter: isaacullah | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Display | Version: 6.4.0 RCs
Keywords: v.digit ppm temp, wingrass | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by hamish):
the empty file versions may be related to #943, core/render.py creates
some temp files without extension, then creates some more in /tmp/ with
e.g. .ppm extension. Note that way cancels the benefit of using
tempfile.mkstemp(), since the temp file created is no longer created in a
secure way, and /tmp is a+w. (at least $MAPSET/.tmp/ is u+w only)
after the empty temp files, there are still .ppm files not being removed
too.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/560#comment:19>
