[GRASS-dev] [GRASS GIS] #943: wxpython gui hangs after switching to cairo display driver
trac at osgeo.org
Sun May 19 01:54:27 PDT 2013
Reporter: epatton | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: cairo, driver, gui, wxpython | Platform: Linux
Cpu: All |
Comment(by hamish):
I notice in wxpython/core/render.py sets GRASS_COMPRESSION=0, but that
doesn't exist, GRASS_PNG_COMPRESSION does. Having that mis-set probably
doesn't help rendering speed & cpu load any.
broken since forever; fixed in all branches.
wrt the tempfiles mentioned in comment:10, I wonder if we can at least
mitigate the left-over-file problem (#560) by putting them in the GISRC
tempdir with something like:
tempfile.mkstemp(suffix = '.ppm',
prefix = os.path.basename(os.path.dirname(os.getenv('GISRC'))) + os.sep
+ 'tmp_')
(? is the GISRC enviro var reset in core/render.py there for the GCP tool,
or..?)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/943#comment:11>
