[GRASS-dev] Using the pygrass "Mapset.glist" method and a dictionary
Nikos Alexandris nik at nikosalexandris.net
Thu May 23 12:50:10 PDT 2013
Hi list.
In a Python script, I use the following pygrass method to retrieve a list of
raster maps:
	from grass.pygrass.gis import Mapset
	landsat_imagery = dict()
	landsat_imagery['Spectral Bands'] = Mapset().glist('rast', pattern =
'B[123457]')
However, whenever the result is empty, i.e. there are no B1, B2 and so on
named raster maps, running the script fails with the error:
'B[123457]')
	TypeError: 'str' object is not callable
Running the instructions step-wise, from within ipython, doesn't appear to be
problematic.  What am I missing in this case?
Thank you for any hints, Nikos
