[GRASS-dev] Using the pygrass "Mapset.glist" method and a dictionary
Pietro Zambelli
peter.zamb at gmail.com
Thu May 23 16:23:28 PDT 2013
Ciao Nikos,
On Thursday 23 May 2013 22:50:10 Nikos Alexandris wrote:
> Hi list.
> In a Python script, I use the following pygrass method to retrieve a list of
> raster maps:
> from grass.pygrass.gis import Mapset
> landsat_imagery = dict()
> landsat_imagery['Spectral Bands'] = Mapset().glist('rast', pattern =
> 'B[123457]')
> However, whenever the result is empty, i.e. there are no B1, B2 and so on
> named raster maps, running the script fails with the error:
> 'B[123457]')
> TypeError: 'str' object is not callable
> Running the instructions step-wise, from within ipython, doesn't appear to
> be problematic. What am I missing in this case?
Mmh...
I've tried your code... and it is working on my machine. In both: python shell
and from file...
Python shell:
>>> Mapset().glist('rast', pattern = 'B[123457]')
['B4', 'B5', 'B1', 'B3', 'B2', 'B7']
>From file:
>>> cat nik.py
pattern='B[123457]')
print landsat_imagery
>>> %run nik.py
{'Spectral Bands': ['B4', 'B5', 'B1', 'B3', 'B2', 'B7']}
Therefore I think that the problem is not here...
can you send me or share/publish the whole code somewhere (gist.github, dpaste
or other).
Cheers
Pietro
