[GRASS-dev] GRASS 6.4.3 release planning
    epi
    massimodisasha at gmail.com
    Sat May 25 12:04:29 PDT 2013
Hi All,
i just tried to build grass6_release from the svn  grass64 svn, Revision: 56411
build is fine, no  errors detected, but without  GUI (wx or tcltk are not working in my case,  montain lion 64 bit build ***)
to test the extension build i tried :
g.extension extension=i.landsat.dehaze
and it worked without errors.
note :
from the g.extension page the example point  to i.landsat.toar (now included as default in grass) we should change it.
i was wondering if the WXgui changes in grass7,  to have it running with wx2.9-cocoa
can be back ported to grass6.x .. is this possible ?
thank you,
Massimo
Il giorno 25/mag/2013, alle ore 12:05, William Kyngesburye <woklist at kyngchaos.com> ha scritto:
> On May 25, 2013, at 5:31 AM, Markus Neteler wrote:
>>> #854: building addons on Mac (assume we can handle post-release in pkg'ing)
>>> --what's the situation?
>> Commonly our Mac packagers package the release (candidate) versions,
>> so we'll know ex-post only.
> I had some time to look at this, and it should be fixed now, for 6.4 at least.  (Mac makefile was out of sync with the main makefile)
> Michael, if you're back or have dev Mac available, (and Hamish, do you have a Mac to try?) - can you verify it works for you?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings.  And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
> - the wisdom of Tarzan
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
