[GRASS-dev] GRASS 6.4.3 release planning
Anna Petrášová
kratochanna at gmail.com
Sat May 25 12:52:51 PDT 2013
On Sat, May 25, 2013 at 9:04 PM, epi <massimodisasha at gmail.com> wrote:
> Hi All,
> i just tried to build grass6_release from the svn grass64 svn, Revision:
> 56411
> build is fine, no errors detected, but without GUI (wx or tcltk are not
> working in my case, montain lion 64 bit build ***)
> to test the extension build i tried :
> g.extension extension=i.landsat.dehaze
> and it worked without errors.
> note :
> from the g.extension page the example point to i.landsat.toar (now
> included as default in grass) we should change it.
> i was wondering if the WXgui changes in grass7, to have it running with
> wx2.9-cocoa
> can be back ported to grass6.x .. is this possible ?
I haven't really thought about backporting it but yes, it's possible
because the changes consist mainly of renaming (wx.Color -> wx.Colour) and
shifting lines (related to sizers). I would have to find relevant
changesets. I would leave 6.4.3 as it is and do it after release not to
break anything.
Anna
> thank you,
> Massimo
> Il giorno 25/mag/2013, alle ore 12:05, William Kyngesburye <
> woklist at kyngchaos.com> ha scritto:
> > On May 25, 2013, at 5:31 AM, Markus Neteler wrote:
> >>> #854: building addons on Mac (assume we can handle post-release in
> pkg'ing)
> >>> --what's the situation?
> >> Commonly our Mac packagers package the release (candidate) versions,
> >> so we'll know ex-post only.
> > I had some time to look at this, and it should be fixed now, for 6.4 at
> least. (Mac makefile was out of sync with the main makefile)
> > Michael, if you're back or have dev Mac available, (and Hamish, do you
> have a Mac to try?) - can you verify it works for you?
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > "Mon Dieu! but they are all alike. Cheating, murdering, lying,
> fighting, and all for things that the beasts of the jungle would not deign
> to possess - money to purchase the effeminate pleasures of weaklings. And
> yet withal bound down by silly customs that make them slaves to their
> unhappy lot while firm in the belief that they be the lords of creation
> enjoying the only real pleasures of existence....
> > - the wisdom of Tarzan
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130525/189a4bfe/attachment.html>
