[GRASS-dev] GRASS 6.4.3 release planning
William Kyngesburye
woklist at kyngchaos.com
Sat May 25 21:02:36 PDT 2013
On May 25, 2013, at 2:52 PM, Anna Petrášová wrote:
>> i was wondering if the WXgui changes in grass7, to have it running with wx2.9-cocoa
>> can be back ported to grass6.x .. is this possible ?
> I haven't really thought about backporting it but yes, it's possible because the changes consist mainly of renaming (wx.Color -> wx.Colour) and shifting lines (related to sizers). I would have to find relevant changesets. I would leave 6.4.3 as it is and do it after release not to break anything.
Oh, I thought 6.4.3 was already fixed for wxpython 2.9 (as I try and see it fail). This is really needed to run the GRASS GUI on OS X 10.7+, especially 10.8.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
