[GRASS-dev] GRASS 6.4.3 release planning
Anna Petrášová kratochanna at gmail.com
Sun May 26 01:36:36 PDT 2013
On Sun, May 26, 2013 at 6:02 AM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> On May 25, 2013, at 2:52 PM, Anna Petrášová wrote:
> >> i was wondering if the WXgui changes in grass7,  to have it running
> with wx2.9-cocoa
> >> can be back ported to grass6.x .. is this possible ?
> > I haven't really thought about backporting it but yes, it's possible
> because the changes consist mainly of renaming (wx.Color -> wx.Colour) and
> shifting lines (related to sizers). I would have to find relevant
> changesets. I would leave 6.4.3 as it is and do it after release not to
> break anything.
> Oh, I thought 6.4.3 was already fixed for wxpython 2.9 (as I try and see
> it fail).  This is really needed to run the GRASS GUI on OS X 10.7+,
> especially 10.8.
So you want to fix it for 6.4.3 now? I can fix some major problems but
there are much more, less obvious, problems, especially on Mac.
Anna
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian]  What are you supposed to do WITH a maniacally depressed robot?
> [Marvin]  You think you have problems?  What are you supposed to do if you
> ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000
> times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130526/1e7a4921/attachment.html>
