[GRASS-dev] [GRASS GIS] #1981: export error in osgeo4w/grass.tmpl
trac at osgeo.org
Mon May 27 17:08:12 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Packaging | Version: svn-trunk
Keywords: scripting | Platform: MSWindows XP
Cpu: Unspecified |
unless I'm misreading something the "export" in osgeo4w/grass.tmpl is
called incorrectly. (all branches)
export $OSGEO4W_ROOT_MSYS $GISBASE $GRASS_SH $GRASS_WISH $GRASS_PYTHON
$PYTHONHOME $GRASS_PROJSHARE
export $PATH
the $VARIABLES get exanded before the command is called, so the
''contents'' of the $VARIABLES get exported, not the variable names. i.e.
when using "export" or "unset", don't add the "$".
also I suspect that in the lines above the enviro variable settings should
be "quoted". (most will just be C:\osgeo4w so not a big deal, but for
correctness/safety/future these things should be fixed..)
ok to change?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1981>
