[GRASS-dev] [GRASS GIS] #1981: export error in osgeo4w/grass.tmpl
GRASS GIS trac at osgeo.org
Tue May 28 12:38:55 PDT 2013
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Packaging    |     Version:  svn-trunk
 Keywords:  scripting    |    Platform:  MSWindows XP
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [ticket:1981 hamish]:
 > ok to change?
 Yes. A "$" in an "export" command is almost always wrong.
 There '''might''' be a situation where "`export $LD_LIBRARY_PATH_VAR`" is
 required, but I think that LD_LIBRARY_PATH_VAR is normally substituted
 rather than ending up in the final script.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1981#comment:1>
