[GRASS-dev] rast_open_new() saturates after opening 127 temporary files
Yann Chemin
ychemin at gmail.com
Tue May 28 19:35:46 PDT 2013
ah yes i am using G7 trunk
On 29 May 2013 08:04, Yann Chemin <ychemin at gmail.com> wrote:
> Hi,
> Linux: Ubuntu 13.04
> ulimit: open files (-n) 1024
> from : http://www.itworld.com/operating-systems/317369/setting-limits-ulimit
> -n The maximum number of open file descriptors (most systems
> do not allow this value to be set)
> indeed:
> ulimit -n unlimited
> bash: ulimit: open files: cannot modify limit: Operation not permitted
> Yann
> On 29 May 2013 01:34, Glynn Clements <glynn at gclements.plus.com> wrote:
>> Yann Chemin wrote:
>>> Opening 127 temporary raster files is the limit of GRASS,
>>> How can I get above that limit?
>> You need to provide more information: version, OS, any error or debug
>> messages generated.
>> I don't have this problem with 7.0 on Linux.
>> But first, check that it isn't an OS issue. "ulimit -n" reports the
>> maximum number of open files (in 7.0, you need two per map). Also,
>> each completed raster needs a subdirectory within the cell_misc
>> directory, and some filesystems impose a limit on the number of
>> subdirectories (often much lower than the limit on the number of
>> files).
