[GRASS-dev] rast_open_new() saturates after opening 127 temporary files
Tue May 28 20:06:26 PDT 2013
Yann Chemin wrote:
> Linux: Ubuntu 13.04
> ulimit: open files                      (-n) 1024
In which case, that isn't the problem.
What type of filesystem are you using? ext2 has a limit of 32768
subdirectories, increased to 64000 in ext4. I know that btrfs has a
rather low limit on the number of hard links (which normally
determines the maximum number of subdirectories, as each
subdirectory's ".." entry is a hard link to its parent).
> indeed:
> ulimit -n unlimited
> bash: ulimit: open files: cannot modify limit: Operation not permitted
You can't increase a soft limit above the corresponding hard limit,
and you can't increase a hard limit unless you're root (and sudo won't
work because the limits are per-process, so ulimit has to be a shell
built-in). On a system which uses PAM, the limits are normally set on
login based upon the contents of /etc/security/limits.conf.
