[GRASS-dev] [GRASS GIS] #1831: wxgui d.vect: layer option should show default applied (1), not -1
GRASS GIS trac at osgeo.org
Wed May 29 06:14:57 PDT 2013
  Reporter:  mlennert     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  critical     |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  d.vect
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by neteler):
  * priority:  blocker => critical
  * version:  6.4.3 RCs => svn-trunk
  * milestone:  6.4.3 => 7.0.0
Comment:
 I have the same troubles in GRASS 7 - reopen this bug report?
 Add new vector -> choose name -> Layer is -1 -> hence no column
 can be selected for display
Ticket URL: <http://trac.osgeo.org/grass/ticket/1831#comment:8>
