[GRASS-dev] [GRASS GIS] #1985: wxGUI: Find module in "Search module" tab fails on Windows
trac at osgeo.org
Fri May 31 12:46:44 PDT 2013
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: Search_module | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:1 annakrat]:
> There is some problem with key events in wx.SearchCtrl widget. Since we
cannot
> fix this, I used wx.TextCtrl for Windows instead. Try r56484.
This helps, working now.
> There is another problem on Windows with Ctrl+Enter shortcut (run found
command).
> It only changes focus to Run button. Is this some special Windows
shortcut?
(any Windows expert here?)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1985#comment:2>
