[GRASS-dev] [GRASS GIS] #1961: wxNVIZ: error if no raster map selected
trac at osgeo.org
Wed May 29 15:33:16 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: wxnviz | Platform: All
Cpu: x86-64 |
Comment(by annakrat):
Replying to [comment:6 hamish]:
> Hi,
> it's better for points now, thanks, but still some small tweaks needed
elsewhere. comments as I go:
some changes applied in grass7 (the code for all branches is almost the
same)
> tested Spearfish's bugsites map in devbr6, looked ok. when tested in the
old 6.4.3svn version only a thin line rendered until I moved the
z-exaggeration slider off 0.0 to 1.0. (which seems like a nice default)
bug in ogsf zexag guess (r56496) fixed
> fwiw there doesn't seem to be a need to abbreviate exaggeration to exag.
since there is lots of space to the right of it for the text.
> restarting the GUI in devbr6 and adding Spearfish's roads did not go
well, nothing rendered, lots of this repeating in the terminal:
> (.:25449): Gtk-CRITICAL **: gtk_range_set_range: assertion `min < max'
failed
> and endless repeating tracebacks:
please test r56500
> Spearfish geology (area) did not render at all. Perhaps it could check
'v.info -t' via vector.vector_info_topo() and if a vector map containing
area features is loaded pop up a warning and offer to render the
boundaries-as-lines instead?
It displays now boundaries by default, centroids can be activated too
(r56495, r56497).
> Going to the wxNVIZ Data tab at that point and trying to add a raster
didn't work, the drop down showed the current mapset and PERMANENT, but no
maps within them and no '>' triangle or so to click to expand them. I
supposed that's what MarkusN experienced too, that list will only show
raster maps already listed in the current Map Display's layer listing.
> Once I've gone back and added it to the layer list it appears, but I
can't edit its attributes-- changing the fine and coarse resolution had no
effect. (could the fine resolution be made a little bit (~20-30%) finer by
default?)
sorry, I cannot reproduce but I know that this error sometimes appears
Ticket URL: <https://trac.osgeo.org/grass/ticket/1961#comment:7>
