[GRASS-dev] [GRASS GIS] #1961: wxNVIZ: error if no raster map selected
GRASS GIS trac at osgeo.org
Thu May 30 11:33:20 PDT 2013
 Reporter:  hamish  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  6.4.3
Component:  wxGUI   |     Version:  svn-develbranch6
 Keywords:  wxnviz  |    Platform:  All
      Cpu:  x86-64  |
Comment(by annakrat):
 Replying to [comment:6 hamish]:
 > and then if I manually go to the Data tab -> Vector controls and tick
 the box to have it render on the newly selected raster map, it stays at
 z=0 below. "Height above surface" there also appears to work as a
 multiplier, not in map units? but of what? the archsites map is not 3D.
 the cat number? interesting raindrop effect, but not so good for accurate
 alignment.
 It should be in map units. The problem appears only when there is no
 surface to drape the points on. Should be fixed in r56515.
 > thanks,
 > Hamish
 > ps- Perspective still needs a hard upper-bound at 180 degrees. currently
 if you type e.g. `325` degrees in the box and move the slider you can see
 where it crosses over itself and the geometry inverts. interesting, but
 not really usable.
 done in r56514
 if you confirm that these fixes help, I will backport them.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1961#comment:8>
