[GRASS-dev] [GRASS GIS] #1961: wxNVIZ: error if no raster map selected
GRASS GIS trac at osgeo.org
Fri May 31 17:29:23 PDT 2013
 Reporter:  hamish  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  6.4.3
Component:  wxGUI   |     Version:  svn-develbranch6
 Keywords:  wxnviz  |    Platform:  All
      Cpu:  x86-64  |
Comment(by hamish):
 Replying to [comment:8 annakrat]:
 > Replying to [comment:6 hamish]:
 > > and then if I manually go to the Data tab -> Vector controls and tick
 the box to have it render on the newly selected raster map, it stays at
 z=0 below. "Height above surface" there also appears to work as a
 multiplier, not in map units? but of what? the archsites map is not 3D.
 the cat number? interesting raindrop effect, but not so good for accurate
 alignment.
 > It should be in map units. The problem appears only when there is no
 surface to drape the points on. Should be fixed in r56515.
 > > ps- Perspective still needs a hard upper-bound at 180 degrees.
 currently if you type e.g. `325` degrees in the box and move the slider
 you can see where it crosses over itself and the geometry inverts.
 interesting, but not really usable.
 > done in r56514
 > if you confirm that these fixes help, I will backport them.
 I tested both of these in trunk, seems ok.
 I also tested adding points without a surface, the first time I again got
 the repeating "Gtk-CRITICAL **: gtk_range_set_range: assertion `min <
 max'" in the terminal, but quitting the gui and restarting it then worked.
 I'll try to test that more later.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1961#comment:9>
