[GRASS-dev] use G_find_raster2() instead of G_find_raster()
Vaclav Petras
wenzeslaus at gmail.com
Fri Nov 1 07:24:48 PDT 2013
Hi Martin and others,
I saw r58135. If one function is preferred, manual should state and explain
it. I also noticed that there is no find...2 function for 3D rasters. If
you understand this topic, please share you knowledge in the manual.
Thanks,
Vaclav
https://trac.osgeo.org/grass/changeset/58135
http://grass.osgeo.org/programming7/find__rast_8c.html
http://grass.osgeo.org/programming7/find__vect_8c.html
http://grass.osgeo.org/programming7/find__rast3d_8c.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131101/239b18b3/attachment.html>
