[GRASS-dev] use G_find_raster2() instead of G_find_raster()
Martin Landa
landa.martin at gmail.com
Fri Nov 1 07:32:09 PDT 2013
Hi Vaclav,
to my knowledge, it's already explained in the manual.
Note: If the user specifies a fully qualified raster map which exists,
then G_find_raster() modifies name by removing the "@<i>mapset</i>".
Martin
2013/11/1 Vaclav Petras <wenzeslaus at gmail.com>:
> Hi Martin and others,
> I saw r58135. If one function is preferred, manual should state and explain
> it. I also noticed that there is no find...2 function for 3D rasters. If you
> understand this topic, please share you knowledge in the manual.
> Thanks,
> Vaclav
> https://trac.osgeo.org/grass/changeset/58135
> http://grass.osgeo.org/programming7/find__rast_8c.html
> http://grass.osgeo.org/programming7/find__vect_8c.html
> http://grass.osgeo.org/programming7/find__rast3d_8c.html
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
