[GRASS-dev] env variable: GRASS_DEBUG_LEVEL
Pietro Zambelli peter.zamb at gmail.com
Sat Nov 9 08:34:32 PST 2013
Dear devs,
reading the manual of G_debug, I found miss leading the documentation:
"Print debugging message if environment variable GRASS_DEBUG_LEVEL is
set to level equal or greater" [0]
So I try to set the environment variable with:
export GRASS_DEBUG_LEVEL=5
but it didn't work. Is It a bug?
Vaclav, tell me that I have to use: "g.gisenv set=DEBUG=0" instead.
Maybe we should improve the documentation string to make it more
clear. What do you think?
Best regards
Pietro
