[GRASS-dev] env variable: GRASS_DEBUG_LEVEL
Luca Delucchi lucadeluge at gmail.com
Sun Nov 10 15:12:35 PST 2013
On 9 November 2013 17:34, Pietro Zambelli <peter.zamb at gmail.com> wrote:
> Dear devs,
ciao Pietro,
> reading the manual of G_debug, I found miss leading the documentation:
> "Print debugging message if environment variable GRASS_DEBUG_LEVEL is
> set to level equal or greater" [0]
> So I try to set the environment variable with:
> export GRASS_DEBUG_LEVEL=5
> but it didn't work. Is It a bug?
I think no
> Vaclav, tell me that I have to use: "g.gisenv set=DEBUG=0" instead.
> Maybe we should improve the documentation string to make it more
> clear. What do you think?
+1 for more documentantion in the doce
There is somenthing here http://grass.osgeo.org/grass70/manuals/variables.html
> Best regards
> Pietro
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
