[GRASS-dev] r.stats area question
Glynn Clements
glynn at gclements.plus.com
Thu Nov 14 03:32:13 PST 2013
Eric Goddard wrote:
> My coordinate system is in U.S. Feet (I know, I know...we're still in
> the dark ages). The numbers do appear to be meters, but I just wanted
> to confirm that the output isn't in feet because of the "assuming the
> map's coordinate system is in meters" part.
Areas are always in square metres, provided that sufficient
information is available to perform conversion.
For lat-lon locations, the conversion is based upon the ellipsoid
parameters and the cell's latitude.
For projected locations, the area per cell is a constant based upon
the location's declared units (i.e. the meters= value in the ouput of
"g.proj -g").
This has been the case since at least the oldest version in the
repository (~14 years ago).
AFAICT, the only situation where you could get output in "map units"
is for an X-Y location or a projected location which lacks a
PROJ_UNITS file.
