[GRASS-dev] Implementation of the High Pass Filter Additive Fusion technique (i.fusion.hpf)
Nikos Alexandris nik at nikosalexandris.net
Thu Nov 14 17:43:54 PST 2013
Here it goes, as Nikos Ves (depending on free time) works on the Python version (and I'll try to
help), the bash proof of concept works. Attached here.
After some initial testing, we think that GRASS' results are just slightly more smooth for when
applying the exact same parameters to get the HPFA Pan-Sharpened material.
To run a test, get the attached tarred file, untar, compile as a grass-addon against G64. Then,
the simplest execution form will be:
# note, the *algorithm* processes each low resolution image separately
i.fusion.hpf pan=lsat7_2000_80 msx=lsat7_2000_10
# or, let's get the usual landsat bands 1, 2 and 3
i.fusion.hpf pan=lsat7_2000_80 msx=lsat7_2000_10,lsat7_2000_20,lsat7_2000_30
# some manual work to rebalance colors (required)
i.landsat.rgb r=hpf_lsat7_2000_30 g=hpf_lsat7_2000_20 b=hpf_lsat7_2000_10
d.mon x0
d.rgb r=hpf_lsat7_2000_30 g=hpf_lsat7_2000_20 b=hpf_lsat7_2000_10
# increase crispness (not very obvious)
i.fusion.hpf pan=lsat7_2000_80 msx=lsat7_2000_10,lsat7_2000_20,lsat7_2000_30 --o
modulator=max
d.mon x1
# hmmm... let's override the algorithms ratio computation
modulator=max ratio=6
d.mon x2
BTW, it works really great with QuickBird imagery. Will upload in the next days screenshots
with freely available HR imagery (i.e. QB2, IKONOS) and Landsat5, 7 and 8. Just a few Landsat
8 screenshots uploaded in the Wiki:
http://grasswiki.osgeo.org/wiki/File:Bengkalis_Island_Landsat8_RGB_Red_NIR_Blue.jpg
http://grasswiki.osgeo.org/wiki/File:Bengkalis_Island_Landsat8_Panchromatic.jpg
http://grasswiki.osgeo.org/wiki/File:Bengkalis_Island_Landsat8_HPFA_Sharpened_RGB_Red_NI
Nikos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131115/f491ed39/attachment-0001.html>
Type: application/x-compressed-tar
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131115/f491ed39/attachment-0001.bin>
