[GRASS-dev] Implementation of the High Pass Filter Additive Fusion technique (i.fusion.hpf)
Nikos Alexandris
nik at nikosalexandris.net
Fri Nov 15 11:35:59 PST 2013
Nikos Alexandris wrote:
> BTW, it works really great with QuickBird imagery.
For the matter,
- the Pan: <http://grasswiki.osgeo.org/wiki/File:Pan_04APR05050541-M2AS-000000186011_01_P001.jpg>
- the MS RGB: <http://grasswiki.osgeo.org/wiki/File:RGB_04APR05050541-M2AS-000000186011_01_P001.jpg>
- the default HPFA Sharpening:
<http://grasswiki.osgeo.org/wiki/File:RGB_HPF_Sharpened_Default_Parameters.jpg>
And, finally, slightly tweaked (other parameters offered by the algorithm/script):
<http://grasswiki.osgeo.org/wiki/File:RGB_HPF_Sharpened_Center_Low_Modulator_Min.jpg>
Nikos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131115/9ef8ed0a/attachment.html>
