[GRASS-dev] r58200 (attempt to fix failure when user name contains non-ascii characters)
Martin Landa landa.martin at gmail.com
Sat Nov 16 01:27:03 PST 2013
2013/11/15 Vaclav Petras <wenzeslaus at gmail.com>:
> Finally, I was able to create a user with non-ascii chars. I tried r58198
> (before Martin's change) and GRASS runs, opens location, saves last open
> location to user settings and loads them afterwards. So, r58200 is not
> needed for that machine.
I can confirm it, strangely when I was producing the patch I was
forced to do also changes in grass.py which were later reverted. So
the change in `core.py` seems to be enough to fix this bug (non-ascii
characters in user name). Please could anyone else confirm it?
Thanks, Martin
