[GRASS-dev] installing GRASS 7 on Ubuntu issue
Rashad M mohammedrashadkm at gmail.com
Tue Nov 19 22:36:34 PST 2013
Hello Michael,
Could you post the log saying that here when installing grass-dev?.
FYI, there is a grass-addons package[1]. But only for grass6
[1] https://code.launchpad.net/~rashadkm/+recipe/grass-addons-req
On Tue, Nov 19, 2013 at 11:32 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>  Thanks much for the explanation. Does anyone know if we need grass-dev
> for running g.extension? For some reason, when we started to install it, we
> got a message that it would wipe out several important software packages we
> are using.
>  Michael
>          ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
>  voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>  On Nov 19, 2013, at 1:57 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
>  yes. this was a bug in packaging which I couldnt get time to fix. But
> installing grass-gui package will help to solve the problem.
>  sudo apt-get install grass-gui
>  sudo apt-get install grass should install everything as this is a
> virtual package but it not doing it right way. I may find some time this
> week to fix these and merge some very important patches from debianGIS.
>  To sum up for now
> you need to install grass like
> apt-get install grass-core grass-gui
>  Let me know if this works so that i can confirm this issue.
> On Tue, Nov 19, 2013 at 4:14 PM, Michael Barton <Michael.Barton at asu.edu>wrote:
>> Turns out that the GUI is a separate download and installation. That
>> seems odd to me, but we managed to solve this.
>> Michael Barton
>> School of Human Evolution &Social Change
>> ...Sent from my iPad
>> > On Nov 19, 2013, at 1:56 AM, "Maris Nartiss" <maris.gis at gmail.com>
>> wrote:
>> > Hello,
>> > as I don't run Ubuntu, could you, please, explain what exactly is
>> > happening. "Skips GUI" sounds too board to understand "when" and "how"
>> > skips. If it's related to compilation, check presence of *-dev
>> > packages. If it's a problem with starting up, run from terminal to get
>> > meaningful error message.
>> > Maris.
>> > 2013/11/18 Michael Barton <Michael.Barton at asu.edu>:
>> >> Hi Hamish,
>> >> The instructions you sent, and added to the WIKI, worked great for
>> >> installing GRASS 7 on 2 Ubuntu boxes. But on the 3rd, it won't install
>> the
>> >> GUI. We've made sure that wxpython (2.8.12.1) and wxwidgets are
>> installed,
>> >> but when GRASS installs, it simply skips the GUI. I assume that it
>> does that
>> >> because it cannot find wxpython/wxwidgets.
>> >> Any idea of how to get around that?
>> >> Thanks
>> >> Michael
>> >> C. Michael Barton
>> >> _______________________________________________
>> >> grass-dev mailing list
>> >> grass-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131120/da8f6c0f/attachment.html>
