[GRASS-dev] installing GRASS 7 on Ubuntu issue
Michael Barton Michael.Barton at asu.edu
Thu Nov 21 21:18:20 PST 2013
Rashad,
Thanks much for your help. Attached is the screen shot we get when we try to install grass-dev.
[cid:4B9D995E-4E98-456D-8D4D-E64F1DDC41FE]
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Nov 19, 2013, at 11:36 PM, Rashad M <mohammedrashadkm at gmail.com<mailto:mohammedrashadkm at gmail.com>> wrote:
Hello Michael,
Could you post the log saying that here when installing grass-dev?.
FYI, there is a grass-addons package[1]. But only for grass6
[1] https://code.launchpad.net/~rashadkm/+recipe/grass-addons-req
On Tue, Nov 19, 2013 at 11:32 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Thanks much for the explanation. Does anyone know if we need grass-dev for running g.extension? For some reason, when we started to install it, we got a message that it would wipe out several important software packages we are using.
Michael
C. Michael Barton
fax:          480-965-7671 (SHESC),  480-727-0709<tel:480-727-0709> (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu<http://csdc.asu.edu/>
On Nov 19, 2013, at 1:57 PM, Rashad M <mohammedrashadkm at gmail.com<mailto:mohammedrashadkm at gmail.com>> wrote:
yes. this was a bug in packaging which I couldnt get time to fix. But installing grass-gui package will help to solve the problem.
sudo apt-get install grass-gui
sudo apt-get install grass should install everything as this is a virtual package but it not doing it right way. I may find some time this week to fix these and merge some very important patches from debianGIS.
To sum up for now
you need to install grass like
apt-get install grass-core grass-gui
Let me know if this works so that i can confirm this issue.
On Tue, Nov 19, 2013 at 4:14 PM, Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>> wrote:
Turns out that the GUI is a separate download and installation. That seems odd to me, but we managed to solve this.
Michael Barton
School of Human Evolution &Social Change
...Sent from my iPad
> On Nov 19, 2013, at 1:56 AM, "Maris Nartiss" <maris.gis at gmail.com<mailto:maris.gis at gmail.com>> wrote:
> Hello,
> as I don't run Ubuntu, could you, please, explain what exactly is
> happening. "Skips GUI" sounds too board to understand "when" and "how"
> skips. If it's related to compilation, check presence of *-dev
> packages. If it's a problem with starting up, run from terminal to get
> meaningful error message.
> Maris.
> 2013/11/18 Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>:
>> Hi Hamish,
>> The instructions you sent, and added to the WIKI, worked great for
>> installing GRASS 7 on 2 Ubuntu boxes. But on the 3rd, it won't install the
>> GUI. We've made sure that wxpython (2.8.12.1) and wxwidgets are installed,
>> but when GRASS installs, it simply skips the GUI. I assume that it does that
>> because it cannot find wxpython/wxwidgets.
>> Any idea of how to get around that?
>> Thanks
>> Michael
>> C. Michael Barton
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
   Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131122/d332259a/attachment-0001.html>
Name: Screenshot UBUNTU.jpeg
Type: image/jpeg
Desc: Screenshot UBUNTU.jpeg
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20131122/d332259a/attachment-0001.jpeg>
